09-06-2013 08:41 PM
My input is a series of differential analog pulses (~5kHz). The input analog pulses are very weak signals, -0.04V~0.08V.
I wanna generate a digital pulse whenever I detect an analog pulse. And then use the generated digital pulses as the trigger of all my other devices.
I looked at the output digital pulses using an oscilloscope. It turns out the the pulses I got are very slow. Please help me figure out where the problem is.
Thanks in advance!
09-09-2013 06:29 PM
09-09-2013 09:07 PM
The pulse frequency is 5kHz.The duty cycle of the pulse is 10%
I wanna make my digital pulses synchronized with the analogy pulses. I think I should use the analog trigger. But I don't know how to use the analog trigger.
		09-10-2013
		04:43 PM
 - last edited on
		03-19-2025
		05:22 PM
 by
			Content Cleaner
09-10-2013 07:35 PM
Thanks for the reply!
Is there any way we can work through this using the 6341?
09-11-2013 01:39 AM - edited 09-11-2013 01:42 AM
Why not build up a little circuit with a comparator?
20mV to 40mV @ 5kHz could be build on any breadboard with a LM393
or use a TL714C with 10mV build in hysteresis and push pull output
09-11-2013 02:02 PM
I guess this is the best way to solve the problem. Thanks!
