Use USB 6341 to generate digital pulses from differential analog input
My input is a series of differential analog pulses (~5kHz). The input analog pulses are very weak signals, -0.04V~0.08V.
I wanna generate a digital pulse whenever I detect an analog pulse. And then use the generated digital pulses as the trigger of all my other devices.
I looked at the output digital pulses using an oscilloscope. It turns out the the pulses I got are very slow. Please help me figure out where the problem is.
Thanks in advance!
(4,749 Views)
How slow are the pulses? Since your digital output is changing via software-timing, you're limited to the response time of your computer. What specific timing requirements do you have for this application?
(4,690 Views)
The pulse frequency is 5kHz.The duty cycle of the pulse is 10%
I wanna make my digital pulses synchronized with the analogy pulses. I think I should use the analog trigger. But I don't know how to use the analog trigger.
(4,680 Views)
Carless,
You're right, analog triggering is how we would accomplish this. Unfortunately, the USB-6341 does not support analog triggering (see specs). Any 635X or 636X X Series would have analog triggering (e.g. USB-6351).  The 632X and 634X do not.
(4,656 Views)
Thanks for the reply!
Is there any way we can work through this using the 6341?
(4,646 Views)
Why not build up a little circuit with a comparator?
20mV to 40mV @ 5kHz could be build on any breadboard with a LM393
or use a TL714C with 10mV build in hysteresis and push pull output
Greetings from Germany
Henrik
LV since v3.1
(4,635 Views)
I guess this is the best way to solve the problem. Thanks!
(4,622 Views)
