Use external Sample Clock for PXI4472
Hi.
I am trying to use a PXI4472 with an external clock.
For the history we have some code working that used the comedi lib and we are now trying to port the code with DAQmx...
I have seen some examples where there is a call to
DAQmxCfgSamplClkTiming(taskHandle, "/Dev1/PFI7"... )
When I try this I have an error
Requested value is not a supported value for this property
Property : DAQmx_SamplClkSrc
You have requested: /Dev1/PFI7
You can select: OnboardClock
1. Does it mean that with DAQmx I only can use the OnboardClock for the 4472 ?
2. I have used PFI7 because I saw it in the example, but I have no idea if it is the right value or not. I didn't find anything about that in the DAQmx C reference Help... Should I use something else ?
Chris
(3,785 Views)
Hi Chris,
You cannot use an external clock with a PXI-4472, because it requires an oversample clock. You'll find more details in this KB: Can I Use an External Clock with My DSA Device?
Luca
(3,768 Views)
Hi.
In fact we have a system where a board generates a clock.
This clock is dispatched on the pxi bus through our backplane.
This clock is a ~20Mhz.
So I want to use this clock (that indeed is an oversample clock).
I agree that the clock for the 4472 will always be generated in local.
I guess that I should try to synchronise my 4472 with the board generating the clock...
Need to check the API to see how to do that.
Chris
(3,706 Views)
Hi
I am looking at the example in "/ansi_c/Synchronisation/Multi-Device/ContinuousAI" to see how I could make it work.
From my understanding, in the example we have:
Dev1 that is the master board. The oversample clock will be dispatched to others boards.
Dev10 is a slave board.
To configure Dev10, a call to DAQmxSetSampClkTimebaseSrc is done with /dev1/SampleClockTimebase
So the ClockTimebase for Dev10 is clearly the same that for Dev1
In my case, I have a custom board instead of the dev1 board.
This custom board generates the oversample clock just like a PXI4472 would do it (trusting hardware guys 🙂 )
But, in my soft,  how can I configure my slave board to use this generated oversample clock ?
As my board is not seen by DAQmx I have no dev1...
Any idea ?
Maybe a way to create a fake board with nidaqmxconfig ?
Chris
(3,687 Views)
