digital output as a small power source
I just want to ask some curiousity about digital output.
Can I use +5V or port0 terminal as a power source (+5V, less than 1mA) without introducing some noise or malfunction?
I atached my PXIe-6124 specification document (page#6).
(2,932 Views)
Hello Labmaster,
The 6124's output high sourcing current is up to 24mA on port 0.  You should be fine with less than 1mA using the line has a power source.   The digital I/O lines are often used as a power source for devices with low power requirements such as relays, LEDs, etc.
Paul C.
(2,925 Views)
