When I try to self-calibrate the 6036E using MAX I get error code -200329, although it will come back fine if I do a self test.
I have also tried to access it in labview. When I open DAQ assistant and try to look at the connection diagram I get the following: 'Error -88302 occurred at DAQ Assistant'.
I am using 32-bit labview 14 in 64-bit windows 7. I have tried installing numerous DAQ drivers, including most recent and the legacy drivers, but I always get the same errors. Is the 6036E just too out of date?
