Multifunction DAQ
Using Vi Logger 1.1 with DAQCARD-1200
I have a DAQCARD-1200 i can have it working with NIDAQ 6.9.3 but i wonder if there is any way to use it with VI Logger 1.1 that don't work with NIDAQ 6.9.3.
Any help apreciated.
Regards.
(3,260 Views)
Hello Riodda,
the requirements for the VI logger are the following:
- Measurement & Automation EXplorer (MAX) version 3.0 or greater.
- NI-DAQ (driver) 7.0 or greater and/or FieldPoint version 4.0 or greater.
- LabVIEW version 7.0 or later
Unfortunately, the last driver compatibility version for the DAQCARD-1200 is the 6.9.3, and so VI logger cannot be used.
A device type similar to the DAQ-1200 is the the NI-6024E, which is compatible with traditional NI-DAQ 7.0.
Fabio
Fabio M.
NI
Principal Engineer
(3,251 Views)
That meas that in some way i can use the driver for the 6024 or that means that i've to dig in ebay for a card like that ?
Regards.
(3,247 Views)
If you want to use VI Logger, you need a new DAQ board. If you have LabVIEW/LabWindows/Visual Basic/C#, etc. you can write a program that uses your DAQCard-1200.
(3,241 Views)
