Hello Ei0Hoda,
The SC-2042-RTD should work fine with your M Series as it says in the following
document . However make sure you connected your SC module correctly as per the following
document. If the connection is correct and you are still experiencing the problem, make sure that you have everything set within the
specs (page 32).
If you are still experiencing trouble, then there might be something wrong with the module. To isolate, test the DAQ device on its own, and if you have another DAQ device, try the module on it.
