Using basic DAQmx drivers for a HS-DIO Card?
I have ready-made programs for Non-HS-DIO cards which uses DAQmx drivers for example basic configuring, reading and writing.
Now I need to use HS-DIO card (NI PXIe-6535). Do I need to regenerate my code and use NI HS-DIO drivers or does it work with old ones? What do I miss if I use old drivers (if they can be used)? Other issues?
BR,
Jick
(6,268 Views)
Hi Jick,
The 6535 does not use NI-HSDIO, it uses NI-DAQmx. I am not sure if your old code will completely transfer over, because the 6535 has its own subset of features that are not on other cards. However, it shouldn't be too much effort to modify your existing code to work with the 6535. Hope this helps.
Kyle A.
Chief Applications Engineer
(6,255 Views)
Ok, thanks for that.
I am wondering why I can't create counter output task in MAX using this device? It says "No supported devices". Purpose is to output PWM signal.
Jick
(6,244 Views)
(6,238 Views)
We do not have counters on the 6535, but you can output a pulse train by streaming a 0101 bit pattern on the generation output continuously at the rate which you need it. To change pulse width, you would have to oversample and add bits, such as 011011, or 001001.
Kyle A.
(6,233 Views)
It has PFIs channels according to spesifications but drivers does not show them for Digital Output generation. What are the PFIs for? Timing? Do I need to use "normal" DO lines for the generation?
What does Supports Pattern I/O mean? Is there some special drivers for pattern generation?
BR,
Jick
(6,211 Views)
You can find this information in the help file located here: 6535/6536/6537 Help
The file is both viewable in HTML and the downloadable .chm. There is also many resources using ni.com search that will help answer these questions. Thank you.
Kyle A.
(6,202 Views)
