Using both internal counters of usb6218
I need to use both the internal counters in the usb6218 device to generate a 10kHz square wave, with one output being the inverse of the other. These two counter outputs need to be routed to any of the digital output pins. So far I have only been able to have 1 timer running at a time. An example of this would be useful.
(3,174 Views)
Would it be possible for you to post your code so far - I could have a look at it for you to get it working with both counters at the same time.
Dan - Applications Engineer NI UK
(3,159 Views)
(3,157 Views)
This query has been continued at the following location:
http://forums.ni.com/ni/board/message?board.id=250&message.id=38453
Tom
Applications Engineering, NI UK
(3,107 Views)
