fwupdate
I am trying to use the fwupdate utility to update the firmware for my usb6009.  I have opensuse10.3 and have successfully installed the daqmxbase.
FWUpdate produces the result....
No protocol specified
Unable to open X display.
if I man FWUpdate I get a bunch of garbage as it's trying to reformat the text, but then stops and does nothing.
FWUpdate -h doesn't supply any help.
lsdaq  produces....
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
Device Error: incompatible firmware.  Serial Number: 012C3DB5
Execute <NI-DAQmx Base directory>/bin/FWUpdate to update.
But again, the FWUpdate isn't getting me anywhere.
What is the correct syntax for performing the firmware update?
Tony
(3,504 Views)
Hi Tony-
Is it possible that you're running into the same issue described in this KB?  FYI- both the DAQmx Test Panels (described in the aforementioned KB) and the DAQmx Base FWUpdate are written in LabVIEW, so both will be susceptible to this same limitation of the X system.
Hopefully this helps-
Tom W
(3,493 Views)
Tom,
Great ! Thanks for the help.  This seems to have worked. I just switched user, had been in terminal as root as during install.  FWUpdate ran and firmware installed!
Now, I can finally get to testing the applications.
Tony
(3,484 Views)
