Using pci 6224
Hi all,
I m using PCI 6224 in one of the solutions. When i connect a floating dc voltage signal to the AI, in differential mode, the voltage level rises. It shows a false voltage. When I measure the voltage by DMM without connecting the cable, the voltage is OK. Can u plz. predict what problem may be?
Regards
GNS
(4,410 Views)
Hi gns,
With floating signal source i would recommend to use RSE (referenced single ended) configuration for your DAQ-card.
BR, Christian
(4,396 Views)
thanks for the reply...
our signal is floating there and we can not connect the negatives of the signals together. can we measure the alll +'s and all -'s in NRSE mode separetely...???  and we defferentiate the value later......will it work..???
(4,393 Views)
Hi gns,
I think the attached picture will help you!
BR, Christian
(4,390 Views)
thanks for your kind support....
cud i have the same doc in english..?? plz...!
(4,386 Views)
HI,
How can we turn the ground reference off in PCi 6224.....??
(4,381 Views)
Sorry for this mistake, I don't have it in english!
The following KB will explain the measurement for floting sources also: [broken link removed]
What do you mean with "turn the ground reference off" ?
BR, Christian
(4,376 Views)
