Verifying MAX calibration
I have used the MAX calibration wizard to set the calibration table for an analogue sensor.  I now wish to verify this using an external standard, and would prefer to see a numeric display of the measured value, similar to that seen in the Calibration Wizard.  Is there a tool anywhere in MAX that can give me a numeric display of the value, or are there only graphs?
Ian Deaville
(3,283 Views)
Hi Ian,
Depending on the device you have you could use the DAQ Assistant to display just a numeric value. If you create a new voltage task for the device and channels you want to measure then you can set the display type within the task configuration to Table.
Regards
Jon B
NIUK
(3,233 Views)
Jon,
Thanks for that.  I did manage to find a Calibration Confirmation gadget built into MAX which does exactly what I want.  It is hidden away in an obscure place, but it is there.  After completing a calibration, select Calibration properties, and in there somewhere is a Verify calibration button.  This process looks very much like the original calibration.
Ian
(3,229 Views)
