Vibration vs rotation speed
Hi..I'm using NI9233 to measure my vibration & NI9411 to measure my engine rotation speed.
Usually I'll do run test separately for vibration & rotation speed.
But now I need to run both the test simultaneously to get vibration vs rotation speed results.
Since both the module applies different type of measurement (Analog for vibration & counter for RPM) with different sampling rate, how can I synchronize the data to get it displayed in vibration vs RPM?
How can I combine both the vi in the same loop?
Please advise.
Attached is my vi:
(3,182 Views)
Hi IVAn,
  I have modifed your VI ,Please see the attached file.You can place in same while loop.
regards.
Syed
(3,148 Views)
