NI 9264 simultaneous signals
Does anyone know if the module NI 9264  for the CDAQ is capable of generating simultaneous analogic signals? I need to control two separate devices at the same time, and am looking for options tom do this. I've got a CDAQ chassis, so if this module isn't capable of doing this, is there any other model I could use?
Thanks.
(3,717 Views)
Your link does not work. The correct one is NI 9264 and the infromation is right there.
(3,707 Views)
Thanks.
Ali,
9264 is capable of generating simultaneous analog outputs and, from what you have written,  you can use it in your application.
Message Edited by kikiduu on 03-24-2009 11:22 PM
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,699 Views)
Hi Ali84,
 The NI 9264 has a dedicated digital to analog converter on each output, so this device is perfectly suited for simultaneous output.
When controlling devices, just be careful of the power consumption of the controlled device. The NI 9264 can only output a maximum of 4mA per channel, never exceeding 16mA for the total module.
That said, this module is suitable for your application.
Salvador Mikel
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,687 Views)
Thanks for the answers. However, I think this module may not be able to generate a 2KHz square signal, so I wonder if there is any other module with at least 2 channels, capable of simultaneous sampling at a higher rate so that I can generate frequencies of 2KHz or more? (Preferably more)
Thanks.
Ali
(3,677 Views)
Hi Ali84,
If you want to generate a square signal I would suggest using a digital output module, like the 9401 which is a 8 Channel Digital Output (sink/source) that can go up to 100MHz.
You can check the complete specifications for this module on the following link:
https://www.ni.com/en-us/shop/model/ni-9401.html
Salvador Mikel
www.ni.com/soporte
(3,655 Views)
