04-01-2007 11:18 AM
04-02-2007 06:38 PM
04-05-2007 02:52 PM
04-06-2007 09:18 AM
04-09-2007 04:54 PM
09-25-2007 03:43 AM
09-26-2007 03:28 PM
Hi TUT,
Unfortunately, the DAQPad-6015 is not compatible with
Windows Vista and the DAQmx readme has been updated to reflect this status, as
seen here. As Elijah mentioned, there are USB products that are better suited to Windows Vista. I apologize for any inconvenience this has caused.
10-02-2007 07:43 AM
Hi all
To update the documentation is not really enough.
We have been using DAQPad-6016 OEM and we have also built a piggyback interface board. This means we have invested some, in a configuration that no longer could be used. It is already cumbersome to buy new PC:s with XP.
My observation is also, that it "works" with 8.3.
I would demand that this issue is addressed more seriously.
1. Fix the problem with in NIDAQmx.
2. Create a supported workaround ( using 8.3.fff)
3.Describe the nature of the problem.
4. Fix the DAQPad hardware, to be compatible
If this is not done it seems like the DAQPad will be discontinued soon.
If this is the case, it is VERY important that such information is sent to all current users!
Carl-Olof
Flexura KB
10-03-2007 03:39 PM
10-06-2007 04:13 AM
Neil
Thanks for your reply.
My dilemma right now is that we want to use the DAQPad OEM together with our proprietary board in new devices, that we build.
Based on your answer it looks like we have to find another solution.
What I really would appreciate is a clear statement from NI, whether this issue is going to be fixed or not.
Otherwise we have to redesign our electronics and possibly avoid NI-solutions...
It really works well for pre-Vista platforms, so we would like to avoid it!
Carl-Olof
Flexura KB
