Multifunction DAQ
Voltage Output Module without Common Ground
I am using the NI-9264 voltage output module. Unfortunately, all grounds are connected with each other.
For my application, I would like to have a module with separated grounds.
Does NI provide such a voltage output module?
Thanks for your answers!
(1,303 Views)
Accepted by Yabudabi
C Series Voltage Output Module
NI-9269 provides Channel-to-Channel isolation.
https://tmesystems.net/
(1,287 Views)
