Voltage limit of BNC 2120 Analog Input
I'm getting a lot of noise from a mV transducer, so I'm going to get an amplifier. I need to know the max voltage that the 2120 is designed for.
(2,816 Views)
JLee,
The BNC 2120 is simply a "fancy" terminal block. As with most terminal blocks, the voltage input limitation is a specification of the DAQ board. Please consult the manual for your board for the proper input limits. Have a great day!
(2,816 Views)
