WFM_Op Stopp
Hi @All,
I try to use theAO Examples in Visual Basic, from the NI-DAQ Software 6.9.3. In this example i have a Sin-Function displayed well, but if i push the "Exit" Button the whole Form is closed.
I only want to "Reset" or "Stopp" the output chanel of my PCI 6014-Card. In other Examples, there i can stopp the output with the Function "cwao.reset" I search in WFM_Options,  but i don`t find the right function for this.
Is there also a function in Visual Basic that stopps or resets the output signal without closing my Project??
Thanks for Help Smiley Wink
(3,138 Views)
Hi @All,
it´s again me, now my problem is still the same. I have the sin-wave and the iteration should be continuous. This is defined by the WFM_Op "0" in Visual Basic. This would work well if i can stopp the generation without closing my projekt! I'm using the PCI 6014. Is there a Function or a command to use to stopp the generation of the sin-wave?
I feel happy if someone can help me with this!
(3,133 Views)
Hi Lokke,
I´ve found an example for you: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EB9F56A4E034080020E74861&p_...
In it there you can find a start and a stop button for the measurement. There is also a quit Button in it which close the whole application.
Hope this helps,
Rebeca Fox
AE, National Instruments, Germany
Rebecca Fox
(3,119 Views)
