Warning 200011 on NI USB-6212
I use NI USB-6212 and example code VC_ContAcq_IntClk.
I have configured sampling rate = 25000Hz.
When I ada up to 10 analog input channels everything is OK.
When I have 11 to 16 channels I get Warning 200011.
Aggregated sampling rate should be 400kHz (16*25kHz)
Why I get this warning, how this affect to my measurements?
Bernard Schmidt
(3,278 Views)
Hi Fizyq,
I looked at our database and this seems to have been a bug with some of our older DAQmx drivers. I would recommend updating the drivers to the latest version of NI-DAQmx  to see if that fixes the problem.
S_Hong
(3,264 Views)
