cDAQ-9172 Internal Software Error occurred in MIO software
    Hello all,
  Recently I have been seeing this error when my CompactDAQ chassis runs with 9233, 9263, and 9205 modules:
                the Labview program crashes, and I get a message stating that an "Internal Software Error occurred in MIO software."
  The system is acting as a controller, taking voltage measurements on the input, and generating voltage signals on the output.  I have not seen this error occur when the program runs in the lab (yet?), where the equipment isn't conencted, but this crash occurs too frequently when in the field (perhaps once or twice in a day).  It has been dealt with by shutting down Labview and restarting the program with a clean memory, or the computer may need a restart.
  The 9233 and 9205 modules act as analog inputs, while the 9263 is generating voltage output.  I'm sorry, but I cannot recall the exact error code at the moment - I'll be sure to, should this error happen again.  The trouble is that this error has happened before: see, the chassis I presently have is a replacement to one that stopped communicating with the computer (one day, the chassis was switched on, and the system did not detect the hardware at all; it was working fine one day, and not working the next).  Prior to the old chassis' malfunction, this error message was appearing on occasion.  Now, I do not know why this "internal software error" occurs from time to time, but I would like to know if it's an indicator that the chassis or any of the modules are in need of repair, or if such an error can be resolved in the program.
  Incidently, when I was trying to search for a solution for the old chassis' miscommunication with the computer, I believe I came across a similar situation.  Through a Google search, I found some people were having problems with those USB hubs that split one USB port into four: USB 2.0 hubs sometimes stopped being detected.  It turns out the solution in some of these cases was to uninstall the USB drivers, and the operating system would reinstall them again, and the hubs would work once more.  I only mention this because I wonder if these errors stem from something occuring in the USB backplane?
  If anyone has seen similar behaviour in the cDAQ chassis, or any modules, please offer up some advice.  I anticipate that I'll be advised to send the hardware in for repairs, but considering that this is a 'new' chassis, then any insight into the situation would be welcomed.
Thank you,
Dan
(3,767 Views)
Hi Dan,
Thanks for describing what you are seeing in detail. The error message seems to hint that there is something going on within the NI-DAQmx driver.  I was wondering if you list which driver version you are currently using and if the same version was being used with your old hardware. One thing which may help this situation is upgrading to the newest driver version or repairing the driver to make sure everything is installed properly. Let me know if this helps.
Kent
(3,738 Views)
  Hey, a response!  Hello Kent,
  I don't recall the previous driver used, but the current version is NI-DAQmx 8.8.0F2.  Around the time of the old chassis, I was trying to reinstall the USB drivers, along with the NI-DAQmx drivers to try and get things working (instead, it ended up needing replacement).  Let me know if there are any other drivers to check on.
Dan
(3,688 Views)
Hi Dan,
Thanks for the additional info.You mentioned that this error occurred in the past. I assume that you were using an older version of NI-DAQmx. Was there a particular version where this error began occurring? In addition, I think it has to do more with the driver installation on that computer rather than the cDAQ chassis itself. If you have another computer that you can test with, I would see if using the cDAQ chassis with the other computer results in the same errors.
Kent
(3,667 Views)
