What are the 2 ADC's on the PCI 6052E for?
The PCI 6052E manual says it has 2 ADC's but the block diagram doesn't show two. Can the two ADC's be used to sample data from two channels in parallel?
thanks.
(2,576 Views)
Page 3-6 of the manual discusses the analog output capabilities of the PCI-6052E card. Also, figure 4-1 on page 4-2 indicates that pins 21, and 22 are DAC1 and DAC0, respectively. Yes, you can use the two channels to output data from two channels simultaneously.
RamziH.
(2,576 Views)
