What is the best way to send out a pulse from the counter output of the DAQ, where the start, stop and pulse-repetition frequency is controlled inside a queued state machine?
I have a queued state machine that I am trying to use to control a counter output, as well as some basic analog voltage signal acquisitions on a USB-6211 DAQ. The state machine passes a boolean true to a conditional structure to start the pulse output on my DAQ. The repetition frequency (1-20 Hz) is controlled using a "wait for next millisecond multiple". While the state machine is sending the "go" command over the queue, the pulse output I'm getting has an unacceptable amount of jitter (+/- 5 Hz). Is there a better way to do this where I could at least maintain my repetition frequency within 1 Hz?
That attached VI does not have the oscilloscope driver included.
Thank you,
-Matt
(3,326 Views)
UPDATE: I generated the actual code from the DAQ Assistant and set up my VI to change the high/low time values. This gave me a very reproduceable pulse train with low jitter. Now the problem is: I can't find a way to start and stop the pulses from a boolean outside of the DAQ VI I created to do this. Any suggestions?
(3,304 Views)
MATCHU,
You can place your DAQ Assistant into a while loop and create a switch button and wire it into the Stop Input from the DAQ Assistant.
Carmen C.
(3,295 Views)
