What is the maximum power on NI usb 6210 ?
Hi all,
I have to measure 400VAC i need therefore a transformator,which makes the voltage lower than -+10V.i need to know maximum power and maximum current for the ni usb 6210,so that i can order the suitable transformator.
Can anybody help me for it ?
thank you!
(3,508 Views)
Main product page with links to the manual and specs.
(3,505 Views)
thank you!
Input current during overvoltage condition -+20mA max/AI pin,so that means maximum current for my DAQ device right?
±20 mA max/AI pin
(3,500 Views)
Hi Gumus,
the Input current during overvoltage condition doesn't contain the information, which you are serching for. If you look in the Datasheet, you will find the following Information:
If the input voltage is approximately 10V, than you can calculate the input current I=U/R= 10V / 10G Ohm = 1nA. Like you see, you don't have to calculate the input current or input power of the NI USB-6210, because the input resistance is so big.
(3,476 Views)
