05-16-2012 08:54 AM
Hi all,
I have to measure 400VAC i need therefore a transformator,which makes the voltage lower than -+10V.i need to know maximum power and maximum current for the ni usb 6210,so that i can order the suitable transformator.
Can anybody help me for it ?
thank you!
05-16-2012
09:00 AM
- last edited on
03-25-2025
08:48 AM
by
Content Cleaner
Main product page with links to the manual and specs.
05-16-2012 09:14 AM
thank you!
Input current during overvoltage condition -+20mA max/AI pin,so that means maximum current for my DAQ device right?
Input current during overvoltage condition |
±20 mA max/AI pin |
05-18-2012 02:36 AM
Hi Gumus,
the Input current during overvoltage condition doesn't contain the information, which you are serching for. If you look in the Datasheet, you will find the following Information:
If the input voltage is approximately 10V, than you can calculate the input current I=U/R= 10V / 10G Ohm = 1nA. Like you see, you don't have to calculate the input current or input power of the NI USB-6210, because the input resistance is so big.
