What is the temperature measurement range for the 9219 and the 9211 modules using a K type thermocouple as the sensor?
hope i've posted in the right place. I'm just about ready to purchase a cDAQ-9172 chassis and some 9211 temperature modules or 9219 universal modules. I haven't quite made my mind up yet. I then thought would either of them do the required temperature range that I require. I need to go from -40°C to +200°C and I will be using a K type thermocouple. Does anyone know what the upper and lower limits are with this configuration?
Mike
(3,538 Views)
Accepted by topic author Mikea01
9211 input specs indicate   Voltage measurement range ..............±80 mV
Quick check on Omega web page http://www.omega.com/temperature/z/pdf/z204-206.pdf indicates this combination will easilly cover your range of operation.
(3,537 Views)
Thanks for that. I just needed to be sure as its a lot to spend especially if I got it wrong.
(3,533 Views)
