Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is the type of audio signal output from DVD?
mqwhale
Member
01-15-2007
05:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it
Floating Signal or
Ground-Referenced Signal?
If I acquire this signal ,which is the best way of test?
RSE? NRES? DIFF?
Thanks!
0
Kudos
Message
1
of 2
(2,910 Views)
Reply
Re: What is the type of audio signal output from DVD?
shoneill
Active Participant
01-15-2007
05:16 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
It depdends on the implementation of your DVD player.
If available, I would look into getting the data via optical connection, this way you can basically define the scheme yourself.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
0
Kudos
Message
2
of 2
(2,908 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
