What is the type of audio signal output from DVD?
Is it Floating Signal or Ground-Referenced Signal?
If I acquire this signal ,which is the best way of test?
RSE? NRES? DIFF?
Thanks!
(2,905 Views)
It depdends on the implementation of your DVD player.
If available, I would look into getting the data via optical connection, this way you can basically define the scheme yourself.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,903 Views)
