What's the best way to access "application contants"?
"My application uses lots of common numeric constants in scalar or array forms.
Is there a way to define those numbers as system constants, like in LabVIEW has lots of them such as "e"; "c" etc.?
If this not possible what is the next best way?
thank you,
Min Shiei
(2,775 Views)
There is no way to make a system constant but there is a way around the issue--create a VI that outputs just one value. This way you can drop your VI when you need the constant value and if you need to update the value in the future, you will need to only make one change.
(2,775 Views)
Hi Jeremy:
Thank you for the information. That's the way I did.
Min
(2,775 Views)
