What should i buy if i want to control a DC motor
Hi there,
I want to control a DC motor with labview. The operation is like turn on and off, change the rotaion speed. What equipment should i buy?
(2,570 Views)
Greetings,
You have numerous options available to you. First, National Instruments has Motion Controllers. Below is a link to the product page for these products:
If you are interested in the Motion Controllers, I would suggest that you post a question to the Motion Discussion Forum linked below:
Since you posted your question to the Multifunction DAQ Discussion Forum, you may be interested in controlling your motor with a DAQ device. Again, this area also provides many options. The E-Se
ries boards have analog input, analog output, digital I/O, and counter channels. It appears that you would need a digital I/O channel to turn the motor on/off and an analog output channel to adjust the motor's speed. Below is a link to the E-Series product page:
E Series Multifunction DAQ
Good luck with your application.
Spencer S.
(2,570 Views)
