What signal events are supported by USB-6216?
I keep getting -200982 error when trying to register events using DAQmxRegisterSignalEvent on my USB-6216.   What events are supported by the 6216?  I cannot find this information in the user manual or anywhere on the web.
(3,215 Views)
Hi Tsquared,
What signal are you trying to register an event for with DAQmxRegisterSignalEvent?  Valid signals include:
DAQmx_Val_SampleClock
DAQmx_Val_SampleCompleteEvent
DAQmx_Val_ChangeDetectionEvent
DAQmx_Val_CounterOutputEvent
The USB-6216 should be able to support these signal types. You can find a complete listing of properties your device supports in the NI-DAQmx C Reference Help under the "Supported Properties by Device" section on the Contents tab.
Barron
Applications Engineering
(3,196 Views)
After additional research I realized that the USB-6216 does not actually support change detection, therefore you will not be able to use DAQmx_Val_ChangeDetectionEvent.  I apologize if my previous post was misleading. You should still be able to register the other events.
Message Edited by Barron S on 03-10-2010 04:07 PM
Barron
(3,180 Views)
