03-09-2010 11:08 AM
03-10-2010 12:14 PM
Hi Tsquared,
What signal are you trying to register an event for with DAQmxRegisterSignalEvent? Valid signals include:
DAQmx_Val_SampleClock
DAQmx_Val_SampleCompleteEvent
DAQmx_Val_ChangeDetectionEvent
DAQmx_Val_CounterOutputEvent
The USB-6216 should be able to support these signal types. You can find a complete listing of properties your device supports in the NI-DAQmx C Reference Help under the "Supported Properties by Device" section on the Contents tab.
03-10-2010 04:07 PM - edited 03-10-2010 04:07 PM
After additional research I realized that the USB-6216 does not actually support change detection, therefore you will not be able to use DAQmx_Val_ChangeDetectionEvent. I apologize if my previous post was misleading. You should still be able to register the other events.
