What the Voltage Output High for the USB-63x3
I'm Evaluating this devices and I need to know whats the Voltage Output High for the Digital IO lines.
Is it this voltage controllable?
Does it support Open Collector?
I'm asking this to see if I will need to have level transalators in order to interface different operational voltages.
Thanks for your support
(3,017 Views)
According to the USB-6343 X Series specifications, the DIO use TTL logic.  This means a 5V level.  The DIO will drive 24mA each.
The levels are not controllable.
They are not open collector.
(3,008 Views)
