signal saturation: is ni9215 the right module?
Hi all,
I need to perform several measurments with this sensor through the analog output and I use the module ni9215. I have created a task and the signal is saturated: I got a constant signal +10.1V. Is the ni9215 the right module for the specified sensor?
Message 1 of 16
(4,817 Views)
The NI 9215 is an Anolog Input/Output Module +-10V and so it is ok for every input in his range.
Which kind of tasj have you create? Have you link the D-Series Inclinometer with module directly or by a series resistance?
It seems like a bad connection or task that you are used.
Giuseppe.
Message 2 of 16
(4,803 Views)
Thanks for your reply. Here the inclinometer spec:
http://www.google.it/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CHQQFjAB&url=http%3A%2F%2Fwww.mea...
When the sensos is not power supplied, I get a very low voltage signal, instead when it is, I get a signal saturation. I defined a continous sampling task.
Message 3 of 16
(4,800 Views)
Can you export the task and insert as attached file here?
Message 4 of 16
(4,796 Views)
Have you resolved your issue?
Message 5 of 16
(4,773 Views)
I'm sorry for the delayied reply, but my coworker is keeping the laptop with Labivew and so I can't show you the task. Tomorrow I should get it back.
Anyway is the sensor compatible with NI9234, too?
Best regards
Message 6 of 16
(4,770 Views)
as I wrote the module is ok for the sensor but you have to check the connection between module and the sensor in order to read the right signal.
Best regards.
Message 7 of 16
(4,764 Views)
Before to connect the sensor to the ni9215, I have connected it to the ni9234 and I'm little bit afraid I have damaged the sensor with it. Is it possible?
Message 8 of 16
(4,760 Views)
Are you using 9215 with screw terminal or with BNC?
Message 9 of 16
(4,756 Views)
I'm using the ni9215 with the screw terminal.
Message 10 of 16
(4,753 Views)
