02-22-2004 03:30 PM
02-25-2004
08:51 AM
- last edited on
11-12-2025
07:46 AM
by
Content Cleaner
Hi Anonymous
Have you tried reading your signals using MAX? You can try reading one channel at a time, or reading all channels. If your problem continues when reading all channels with MAX, then you may have a problem with charge injection.
Here is a link that may help with that.
If your readings work in MAX, then your problem is probably with your program. Are you using LabVIEW?
Good luck
Russell G.
Applications Engineering
