When I send an ai_read to my ATMIO64-E sometimes I get a bad read
I'm having problems reading signals, actually I have some Amperage
signals and some temperature, when I read Amperage alone I have no
problems, but when I read (ai_read or ai_vread or CWAI or CWAIPoint)
multiple ports consecutive, the value is wrong.
(2,506 Views)
Hi Anonymous
Have you tried reading your signals using MAX? You can try reading one channel at a time, or reading all channels. If your problem continues when reading all channels with MAX, then you may have a problem with charge injection.
Here is a link that may help with that.
If your readings work in MAX, then your problem is probably with your program. Are you using LabVIEW?
Good luck
Russell G.
Applications Engineering
(2,506 Views)
