Where do I plug the + and - ?
I need to control a control valve with a voltage 0...10 V.
I have to connect a "+" and a "-" wires. If I plug them wrong they burn.
In my NI-9263 I have
AO0
COM
AO1
COM
AO2
COM
AO3
COM
NC
COM
So a channel is by example AO0 and COM.
But does the + goes on AO0 and the - on COM, or the - on AO0 and the + on COM ?
Thanks a lot !
Is there a source where I can verify that ? I haven't found anything in the NI9263 datasheet.
Thanks a lot (cf picture)
(2,023 Views)
COM = GND = -.  So - goes to the COM and + goes to AOx.
(2,008 Views)
Also look at the valve and make sure it does not exceed the available current draw. What kind of circuitry does it have?
(1,991 Views)
