Who can supply me with 68-pin D-type connectors?
I'm building a custom circuit which will connect to an NI DAQ board via an SH1006868 cable. This means that the interface needs to be via a pair of 68-pin D-type connectors. However, I can't find anyone who makes or sells these. Can anyone direct me to a source? I've checked Digikey, Mouser, Newark, Amphenol and 3M...no luck.
(3,113 Views)
I believe you should be able to find what you need in the following Knowledge Base article.
Specifications and Manufacturers for Board Mating Connectors
It lists several AMP part numbers depending on whether you want verticle, right-angle etc... Let me know if you have any trouble finding something.
I hope this helps!
Russell
http://www.ni.com/support
(3,113 Views)
