Why Do I Get Load Error Code 11 Right After Installation?
I installed Labview 6.0 without MAX, and Ni-DAQ 6.1. During the installation of DAQ, I selected Labview 5.0 support. OS is Windows NT 4.0 and the device is AT-MIO 16. I followed the steps according to the knowledgebase such as copying daq*.mnu to menu/daq folder and tried to run Labview. But, when I clicked "DAQ solution" button, it showed "Labview error code 11: VI version (5.0) cannot be converted to the current Labview version (6.0)because it has no block diagram." I checked and tried to follow couple of knowledge bases regarding code 11, but no success.
(2,977 Views)
To help troubleshoot this issue, please verify that you have followed the proper installation steps for using older versions of NI-DAQ with newer versions of LabVIEW:
How Do I Use Older Versions of NI-DAQ (6.8 or Earlier) with LabVIEW 6.x?
http://digital.ni.com/public.nsf/websearch/F7D5934AF18EAA038625694600453DF2?OpenDocument
Making DAQ VIs Visible when Using NI-DAQ 6.1.x with LabVIEW 6.0
http://digital.ni.com/public.nsf/websearch/CACF9DEEC9DEB99086256ADB0071B94E?OpenDocument
Hope this helps. Have a great day!
(2,977 Views)
Thanks.
Unfortunately(fortunately?), I followed every step including the above two KBs. But, whenever I clicked DAQ solution wazard menu, no matther where I am, it shows that error code 11. I uninstalled everything and followed the procedure over and over again, but always having the same problems. What can I do next?
(2,977 Views)
I'm having the exact same problem in a similar solution. Yes, I followed the recommended installation steps. They don't solve the problem.
(2,977 Views)
Allow me to try a different approach - what are you trying to accomplish exactly? If you are just looking for DAQ Examples, try this: launch LabVIEW and click on Find Examples (or in the Menu Bar, Help>>Find Examples). If you can provide specific information about your application, I can help lead you in a better direction. I look forward to your post. Have a great day!
(2,977 Views)
