analog input channel 0 can not work (PCI-mio-16E-4)
I use above daq board connected to daq signal accessory. On the test panels is shown an unusual reading.I would like to confirm is it channel 0 work perfect? I got 6 labview stations in my university (university of central oklahoma). Only this station can not measure temperature.
(2,852 Views)
Your "bad" channel looks more like it's been grounded. I don't know how you have your daq signal accessory hooked up, but has a pin bent? Can you put an ohmmeter on the input pins of the card, and verify that they are not shorted?
Mark
(2,851 Views)
Thanks for your reply. I alreaday use the ohmmeter to check board,but it isn't shorted to ground. Do you have any solution for it? Thanks
(2,851 Views)
Is it shorted when you connect your signal to it?
Mark
(2,851 Views)
