Why am I getting error -1967362020 if I run the compiled code?
I want to change the Binding URL of a shared variable from an application (EXE). I have used the "property node" to modify two attributes "enable binding" and "Network URL". I have tested the VI under labview development project and obtained a successful result; however once I compiled the vi and run the executable it brings an error number -1967362020.
(3,463 Views)
Hi
This was reported to R&D (# 47FTC7ETM) for further investigation. R&D is currently investigating this issue.
Thank you for your feedback.
Mehak D.
(3,444 Views)
There was a typo in the previous e-mail. The CAR ID is 4FTC7ETM.
Also, using 8.2.1 is a possible workaround for this matter.
I hope this helps!
Mehak D.
(3,409 Views)
I am getting this error using LV 8.5 when trying to build my application. I works great in development environment but produces this error when builded.
Property Node (arg 1) in AT-SV Lookup.vi->demoSV.vi
Error code is -1967362020
/soren jensen
(3,283 Views)
