Why cant I connect to my device? Error code 50802
With one computer, I am able to see my 9163 device when connected throught the LAN line and do anything I need with it .  When I disconnect and take it to another computer, I can see the device through MAX but cannot connect to it.  When I try I get error 50208.  I have checked the proxy setting and it is unchecked.
I have the current firmware (1.1.0f2).
Any other advice for me?
(3,218 Views)
Since the device is working succcessfully in the first computer, please review the network configuration settings in the second computer/compare the settings with the first computer/contact your Network administrator to ensure that both computers have similar settings. In some cases, certain third party software e.g. VPN clients create additional network connection entries in the Windows Operating System. When this happens, each entry may have a unique IP address assigned to it by the host computer even when not connected to a route. Please refer to the following recommended troubleshooting steps for the initial setup of the NI WLS/ENET-9163; as well as the comprehensive selection of troubleshooting resources for the NI WLS/ENET-9163 which have been included below.
1. Troubleshooting NI WLS/ENET-9163 Initial Setup Issues:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015BWHSA2&l=en-US
2. Troubleshooting Resources for the NI WLS/ENET-9163:
http://digital.ni.com/public.nsf/allkb/85F0E0316EFBA819862575A2006B8D63
Ali M
Message Edited by Ali M on 02-16-2010 03:18 PM
Message Edited by Ali M on 02-16-2010 03:22 PM
(3,204 Views)
