Why do I get error 200428 for counter output?
I am using labview 7.1 and NI-DAQmx BASE for Mac OS X with an NI USB-6009. Whenever I try to use counter output to generate a digital pulse I get error 200428 at an unknown location. This happens even with example VIs. The example VI that I am trying to use is examples/daqmxbase/dynamic/ctr/Gen Dig Pulse.vi.
(3,891 Views)
HI Jack,
There are a couple of things you can try, First, open the VI, save it and close it. Then reopen and see if it works. Here is a knowledge base article that you might find helpful.
Hope this helps.
Have a good one.
Malay Duggar
NI
(3,876 Views)
Hi Jack-
Actually, the reason you're receiving that error is that the USB-6009 does not support counter output operations.  The counter hardware only supports falling-edge simple event counting.  If you need counter output operations I would encourage you to upgrade to a USB or PCI M Series device.
Hopefully this helps-
Tom W
(3,868 Views)
I'm having the same problem with my Mac OS X using the USB-6009 except I'm actually trying to use it as an input counter, to count pules. I keep getting the Error 200428. I'm pretty sure it may have to do with the specific settings in the task configuration but it won't let me change any of the options. Any ideas?
(3,567 Views)
Have you looked at this knowledgebase article yet?
NI-DAQmx Base Error -200428
Eric S.
AE Specialist | Global Support
(3,541 Views)
Thanks Eric S! That's what I needed!
(3,531 Views)
Glad to hear it worked!
Eric S.
(3,519 Views)
