Multifunction DAQ
Why does making my AO Create a subVI not work?
I have a PCI-6251. I make a simple DAQmx write sequence using a Create Task, Create Channel, Write, and Clear. It works fine.
When I copy/paste the Create Task, Create Channel blocks and make them a subVI with the proper connectors and all, it does not work. Is there some VI Property I need to change or set on the subVI?
(3,285 Views)
Accepted by lindope
Sorry, the output_test.vi should have a different Task and Channel Name than appear in my attachments so as not to be the same as the subVI.
I just set the VI Properties for the subVI by unchecking the Reentrant execution and it seems to work everytime now.
Did I just solve my own problem?
(3,277 Views)
Hi lindope-
     As long as everything is up and running dependably, yes, you did solve your own problem!
     Did you accept your own solution?  Smiley Very Happy
Gary P.
Applications Engineer
(3,253 Views)
Too bad I can't give myself Kudos.
(3,240 Views)
