Why does making my AO Create a subVI not work?
I have a PCI-6251. I make a simple DAQmx write sequence using a Create Task, Create Channel, Write, and Clear. It works fine.
When I copy/paste the Create Task, Create Channel blocks and make them a subVI with the proper connectors and all, it does not work. Is there some VI Property I need to change or set on the subVI?
(3,267 Views)
Accepted by topic author lindope
Sorry, the output_test.vi should have a different Task and Channel Name than appear in my attachments so as not to be the same as the subVI.
I just set the VI Properties for the subVI by unchecking the Reentrant execution and it seems to work everytime now.
Did I just solve my own problem?
(3,259 Views)
Hi lindope-
     As long as everything is up and running dependably, yes, you did solve your own problem!
     Did you accept your own solution?  Smiley Very Happy
Gary P.
(3,235 Views)
Too bad I can't give myself Kudos.
(3,222 Views)
