I have an application set up in which a 556 timer is being used to generate a pulsing signal in order to flash some LEDs. This same signal is used as an input trigger(treated as a Digital A trigger) to my LabView program. The problem is that whenever I plug the PFI0/TRIG1 line into my circuit board(at the same place as the output to the LEDs) to acquire the signal, the pulse waveform dies.(goes to all zeroes) Do you know why this might be happening? Is there somewhere that I need to configure the PFI0 line? Am I maybe missing a ground for the PFI0 line?
Bryan
