Multifunction DAQ
Why does my card have a 12 volt dc offset
I recently got my card working under linux and I've been running a few of the example programs written in c.
I hooked up a signal generator to my card, with the signal going into AD0 and the ground plugged into AD GND.  I also have the same signal going into an oscilloscope and a volt meter (for sanity checking).  I have found that the voltage being measured in my program is coming out around 12 volts more negative then what I'm putting in.
At first I thought it might be the signal generator that was producing the 12 Volt DC offset but this doesn't make sense for 2 reasons. The volt meter is measuring the correct voltage across the input leads into my NIDAQmx - 6254.
I've attached the code I'm using...
(3,345 Views)
I've tried calibrating the card using both the internal and external calibration function calls:
DAQmxErrChk (DAQmxSelfCal("Dev1"));
DAQmxErrChk (DAQmxInitExtCal("Dev1", "NI", &calHandle));
 But the voltages I'm reading out still have the DC offset.
(3,321 Views)
Dear nerostu,
That is a quite interesting behavior. What if you measure a known voltage source such as a battery to see what kind of reading do you get on your M series card. What kind of range did you choose? Do you have any custom scaling activated?
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(3,312 Views)
Accepted by neurostu
Thanks for your reply, I actually just figured out what was wrong, I feel pretty stupid but the example script was referencing AI0 against AI1 and not against ground, which is what I assumed it did. When I fixed this the DC offset went away.
(3,310 Views)
