With > 1 grounded source, are there ground loops in NRSE?
I understand that when one grounded source is connected to LabView in NRSE configuration, there are no ground loops;
and that this is consistent with the recommendation in:
       Field Wiring and Noise Considerations for Analog Signals
http://zone.ni.com/devzone/cda/tut/p/id/3344
My question is:   if more than one grounded source is connected in NRSE configuration,
                         does this cause ground loops, since the input commons are all connected
                         to AI-Sense, no matter what the state of the multiplexer?
Thanks and Regards,
Mike Saginaw
(2,868 Views)
Hi Mike,
Yes, if more than one grounded source is connected in a NRSE connection, you will get a grounding loop.  And yes, the input commons are all connected to AI-Sense, no matter what the state of the multiplexer.  Here is a link to a National Instruments webpage on grounding:
Ground Loops: Measuring Grounded Signal Sources
If you absolutely must use NRSE, I would suggest plugging in your measurement device and signal source into the same wall outlet to increase the chance that they will have the same ground.
I hope this helps!
- Erik
Message Edited by Erik J on 12-14-2006 09:51 AM
(2,855 Views)
