12-13-2006 05:39 PM
12-14-2006 09:25 AM
Please post the code. There's a very good chance that the structure of the code is responsible for the delay you observe. One typical situation would be something like this:
- Call to DAQmx Timing with settings for finite sampling of ~4000 data points, sampling rate of 2 Hz (corresponds to the 0.5 sec interval you mentioned).
- Call DAQmx Start
- Call to DAQmx Read with input for "# sample to read" unwired. When unwired, the default value of (-1) is used, meaning "read all data after the entire finite buffer has been filled". 4000 points at 2 Hz will take 2000 seconds (33+ minutes) to acquire. Had you sampled at 1 kHz, it'd only take 4 seconds instead.
That's all the time I've got now except to assure you that there *are* ways to structure your code that let you update graph displays regularly throughout a long acquisition. A key term to search for is "Producer-Consumer architecture."
-Kevin P.
12-14-2006 09:43 AM
12-14-2006 09:46 AM
Hi Santa,
Are you using the VI Logger interface in MAX or LabVIEW? You are right when you assumed that there is a minimum amount of data required to update the display. The way VI Logger works is that it does not update the display until the full amount of samples per channel have been acquired. For example, if you set up your VI Logger task to read continuously at 2Hz with 2 samples per channel, it will only take 1 second to update the display. But if you are sampling at 2Hz and specify 100 samples per channel, it will take 50 seconds for the data to display. It will display those 100 points, then wait another 50 seconds to display the next 100...and so on. That being said, it would take a setting of 4200 samples per channel (at 2Hz) to achieve a delay of 35 minutes (4200 / 2 = 2100 seconds = 35 minutes). So can you tell me what setting you have in your task for Samples to Read? If it is very high (like 4000), try setting it to 10 and let me know if it still bogs down your PC.
As far as the button... when your task is not running you should see a green Run task button at the top of MAX. When the task is running you should see a red Stop task button. Do you see different behaviour? If so, what version of MAX and DAQmx do you have? (please verify that it is DAQmx 8.3) Also, are you using VI Logger Lite or VI Logger Full?
Nicholas B, National Instruments
12-14-2006 09:49 AM - edited 12-14-2006 09:49 AM
Hi Santaprene-
The same limitations Kevin points to could possibly also slow operation in VI Logger. Can you please list the settings you use for Acquisition Mode, Samples to Read, and Rate?
EDIT: Nick beat me to it with a more thorough explanation...![]()
Thanks-
Message Edited by Tom W [DE] on 12-14-2006 09:50 AM
12-14-2006 10:50 AM
Samples to read: 1000Acqusition mode:
Rate (Hz) 500m
continousClock type:
Internal
12-14-2006 10:58 AM
Hi Santa,
Thank you for the info. So if you take a look at my previous post, this 35 minute delay is expected with the parameters you have set. You are telling VI Logger to wait until 1000 samples have been read. And when the acquisition is performed at a rate of 0.5Hz, it takes 2000 seconds (or 33.333) minutes to acquire the 1000 samples.
To reduce the time, increase your sample rate or decrease the numper of Samples to read. With such a slow sampling rate, even setting Samples to read to a value of 1 will still take 2 seconds to display.
Let me know if you have any additional questions, comments, or concerns.
12-14-2006 10:58 AM - edited 12-14-2006 10:58 AM
Hi Santaprene-
Your combination of rate and samples to read mean that it will take (1/.5)*1000 = 2000s to return each time. This is ~33 minutes and likely the cause of the delay you're seeing. Adjust the samples to read to something reasonable given the sampling rate and the delay should go away.
Hopefully this helps-
Message Edited by Tom W [DE] on 12-14-2006 10:59 AM
12-14-2006 11:37 AM
12-14-2006 11:39 AM
