DAQ-MX 8.3 freezes on slow sampling rates
Its just the NI software that is unresponsive, kernel runs at 100%, other apps run but are slow.
Message 11 of 12
(813 Views)
Samples to Read is NOT a graph scaling issue. The sample rate tells the DAQ board how fast to accumulate samples in the buffer. The number of samples tells the board how many samples to accumulate in the buffer before doing a transfer. With a sample rate of .5 hz, if you specified number of samples to be 2, you would get 2 samples every second. As already explained, specifying 1000 samples makes your program unresponsive but it is unresponsive because of what you have specified.
Message 12 of 12
(802 Views)
