WriteDigChan-ExtClk
I ran the sample program
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Generate Values\Write Dig Chan-Ext Clk, but got a message as below:
DAQmx Error: Requested value is not a supported value for this property. The pro
perty value may be invalid because it conflicts with another property.
Property: DAQmx_SampTimingType
Requested Value: DAQmx_Val_SampClk
You Can Select: DAQmx_Val_OnDemand
Task Name: _unnamedTask<0>
Status Code: -200077
End of program, press Enter key to quit.
I'm using USB-6001 and nothing is connected to it except usb cable.
Could you give any advice regarding this error?
Thanks!
(4,883 Views)
The digital lines on the 6001 are software timed (a.k.a. "On Demand") only as per the device specifications.
Best Regards,
John Passiak
(4,874 Views)
Is it possible to send two outputs as below with an accurate delay time with USB-6001?
Could you please suggest any way to implement it?
(4,869 Views)
If you can use the Analog Output lines for this task (i.e. you are not already using them for something else) you will be much better off--they can be clocked at up to 5 kHz.
If not, you'll have to use software-timed digital output--I wouldn't consider the timing of this particularly accurate but it might be useable for some applications.
Best Regards,
John Passiak
(4,863 Views)
